Opentracker
I'm hooking up a car lift and it has the normal two wires coming out to get juice. The odd thing is that the push button on/off switch is in line on only one wire, the other one looks like it was hooked up all the time. I didn't see how it was hooked up before so I don't know how the PO did it. The switch has just one pole on each side, like any other single switch. Does this motor run with only one hot wire switched? Sounds odd to me. Wouldn't it need a switch with 4 poles?
