Ok, so far I have the EFI running (speed density) after having some injector issues with two of them not squirting. Picked up a cheap stethoscope from our Chinese buddies at harbor freight. Worked great and got the injectors (replaced those two) all working now. Got everything running pretty good except for one issue. There is a small stumble when I step on the gas pedal. It is just for a second at low rpm and quickly goes away as it revs up. What is interesting if this is the same stumble that was present when I still had the edelb. carb on there. I had a 2.5" exhaust and midlength headers put on when the carb was still on and the stumbles was there and a little worse back then. This is a mystery? I replaced the tps/iac and adjusted the tps a little and that did not remove it. Running 12 btdc timing. Any ideas here?
