SELLERSRODSHOP
finally got around to ordering my new radiator last week & it arrived on today's UPS run. i bought the larger 25" radiator with the inlet/outlet on opposite sides, so will have to fab up a crossover pipe for the lower hose. i'm really impressed with the quality of the part considering it was only $199.
after looking over jonk67's thread on mounting the wider radiator with side mounts instead of the stock saddle type, i'm going to expand on his idea by fabbing up a pair of "C" channels that will mount to the core support like his, but wrap completely around the sides & over the rear core a couple inches to temporarily mount my stock 20" fan shroud. doing it this way i can later swap to a elec fan setup & mount it to the channel along with the relay & adjustable temp switch. an overflow tube can also be mounted on the opposite channel.
what is the best way to flush the block to clean it out before putting the new rad in? thinking about running the "dexcool" red coolant in this assembly.
