tarafied1
yes sir!You do realize they are talking about a straight axle set-up, right? For the front end.![]()
inside rail dimensions are about 26.4"I will need to make some measurements
yeah, it will probably be way too wideDon't forget to look at the track width too... that's what you will need to see if it fits within the fenders...
that looks way better than the boat anchor that was in there!Engine is all together and ready to start, Plug wires are off in the picture but are now on.View attachment 26225
can't wait to see it!I doubt I will have the Crown Vic front end installed before the power tour now. So you can check out the front axle on the truck during the tour.
YepI'm not sure if it's required for your combination, but on the 5.0 / T5 combo, there is an aluminum plate that goes between the bellhousing and the transmission. It's probably just shy of an 1/8" thick. If one wasn't installed, you might want to see if that could be the source of the converter being pushed in too deep.
