68stang289
70 Mustang that was factory drum/drum. I did the switch to factory 70 front discs and installed a Wilwood or Baer (I forget which off hand) proportioning valve. When bleeding the brakes I have fluid to the front discs, but I don't have fluid to the rear drums. I have tried adjusting the prop valve, but still no rear drums fluid when you attempt to bleed them. The pedal is pretty hard to press down. Any thoughts on what might be causing the issue and/or how to fix it?
