not bad for three days....
SELLERSRODSHOP
they started on the new shop on weds. looks like they are almost ready to start putting metal on..
Hey Steve, as Freddy Prince would say 'Looooking Good!' I hope to be able to swing by this weekend (29-30) and check in. Looks like you added a window where the TV was so you can see people pulling up. Are you mostly at Pops or around the house on weekends?
Jon
Jon
the other one had a window there too, just usually kept the blinds closed at night. best to just give me a call before you drop by. with things so crazy right now, i'm not on a set schedule. just try to get out to pops & work when i can.
this is an exact replacement externally to what i had, i'm just making some changes inside. the builder even pulled the original build order from 96 & based this order on that. hope they have it finished outside next week. after the progress sat, there isnt much left but hanging a few pieces of metal & the doors. then it gets inspected, the insulation added & interior walls & ceiling attached. after that, wiring, lights & looking for a HVAC system. here's what they did today:
Congrats Steve, looking good I know you can't wait until it get done. Then you can get things back to normal and start doing what you enjoy.
Wow, looks like they added a doggy door :pbj
I guess that's why I never noticed the window as it was covered. I'll give you a call, I changed my cell to a local 615 number finally.
Jon
well, except for the two subcontract jobs (garage doors & ceiling insulation) the bldg was completed in 5 days. i've spent the last two days with a diamond grinder resurfacing the floor to prep for a new coating. if you've never used one of these consider yourself lucky. i can't hardly move tonite. those things beat the ca-ca out of you. kinda like driving a 40 ford with bad bias ply tires & worn kingpins on a bumpy road. :rant did go to the equipment place yesterday & put some more items in my "sold" pile. got a heckuva deal on a new mill, bandsaw, 9x48 belt sander/ 9" disc combo, & a 1500cfm air filtration system.
i upgraded the interior package with this one, 6" thick r-19 blanket insulation in the walls & 12" blown into the ceiling. you can see how thick the walls are now at the window frames. much better than the 1.75" styrofoam board in there before :thu
Gettin' close and lookin' good for sure. Bet it took more than a couple of :gs to fill the walls...... :roll
