I have a small oil leak. The leak is at front corner of the oil pan where the PO mounted a billet dipstick housing/tube. The gasket between the oil pan and the base of the block sticks out at the leaking corner and appears to be a cork-like material. Should I drop the oil pan and replace that gasket with something else? Any advice for stopping this small leak?
