:stu You'll more than likely spend more time fixing your perfect repo than you will smoothing out the original."Horseplay" said:Do you have said "perfect" repop and have you test fit it? I can't recall anyone ever reporting a well fitting repop rear valance. I wouldn't let any original metal go until I knew for sure I had a good replacement. Same goes for your fender. It is worth the little needed repair rather than fighting with an inferior repop. Just MHO.
