Robs66Coupe
Hey guys. How long, in general, does it take to set up a paint gun, mix epoxy, and clean up a gun. Obviously, the time will vary a bit if you're new vs experienced, how much you have to paint, etc. But I'm talking just the setup and cleanup time. I've heard stuff about epoxy not sticking to acid so I'm toying with the idea of getting a gun and I can spray every piece as it goes in.
Also, what would you think about spraying parts before they go onto the car? So, order the part, receive it, clean it and hit it with epoxy right away, that way if I don't get to install soon, it's protected. Then when I go to install, clean up where I need to weld, and epoxy over it all again once it's in. Keep in mind most of my work right now will be on the inside and not seen.
Thanks
Thanks
