Runningriot
I know a guy that has a used paxton set up from paradise wheels for sale and I'm curious if it would work with my motor. I can't beat the price he's offering and I don't want to pass up the oportunity if it would work.
The set up includes the old school air box like this:
a sn93 supercharger, carter fuel pump, pulleys, tension bar and intake hose. He is also including a race prepped, no choke, 750 DP Holley that is tuned to work with this set up.
My motor is a 87 GT 5.0 roller block with, 93 gt-40 heads, Edelbrock Air-Gap intake and Cran's 1:6 Roller Rockers.
My cam is a Trick flow stage 1
duration @ .050" = 221 int./225 exh.
Valve Lift with 1.6 rockers = 0.499 int./0.510 exh.
cam lift = .312/.319
I'm also concerned with clearance for the air box as well as mounting the supercharger because my valve covers are 5.5" tall (I previously had clearance issues with my roller rockers)
So with my motor set up, my cam and valve covers, would I be safe and capable of running a Paxton?
Any help would be greatly appreciated!
