Do you have to run the PCV hose from the left valve cover into the carb. or can you just use 1 vented breather cap on each valve cover if your carb. is not set up for the hose ??
"70 StangMan" said:Thank's Mark...my new carb. doesn't have the inlet for the PCV and was hoping I could just get another breather cap and move on. :steer
"70 StangMan" said:Do you have to run the PCV hose from the left valve cover into the carb. or can you just use 1 vented breather cap on each valve cover if your carb. is not set up for the hose ??
I am really liking this idea. I have never liked having not just a PCV set-up on a VC but ANYTHING on them. This would seem a way to eliminate anything altogether which is the look I want."Mach1Rider" said:I am using vented caps on both Vc's but have tapped the intake at the valley with a port and tubed up to the air cleaner inside the filter.
This is drawing air in thru the caps and out of the crankcase.
"Starfury" said:Mach: so you run no PCV valve in that tube?
I'm still trying to figure out how to prevent my PCV system from sucking oil out of the crankcase. I spin my motor up to 6k regularly and have issues with oil getting drawn into the intake.
