67resto-coupe
Ok, so the last time my motor died unexpectedly, it was traced back to the jumper wire to the + terminal on my coil.
It still starts and runs, but I'm having a mean case of bad idle/stumble/richness issue. Nothing has changed on my motor.
The hesitation/stumble is at idle and runs up to about 15-2k rpm, then it runs fine all thru the rpm range. I don't have a tach, so I can't be specific.
I'm wondering, is it possible that this jumper wire has a small short causing the stumble, then as the rpms increase, that short becomes less apparent because there's a stronger current thru the ignition system?
I'm thinking I may need to re-do this jumper. Right now, I'm using a quick-splice terminal to jump off the orig wire off the ign switch and I have new wire going thru the firewall to the + coil terminal. Any tips on pulling the wire cluster off the back of the switch? Should I just butt splice the 2 wires for the best connection?
Thanks.
Thanks.
