More like unsoldering. I am trying to heat a joint to pull it apart. There is maybe 1 inch of 3/4 copper pipe coming out of the house in the backyard, then the soldered joint. Cleaned all the paint off of the pipe heated with MAP gas being careful not to overheat the copper. Tried twisting, pulling and rocking back and forth. It will not budge. Not sure how old the joint is, a guess would be older than my teenage daughter. :hs
My next thought was to dremel it apart.
Plan "C" would be cut it off and use a Coupling. Plan "A" was to use a 90 and go down T with my hose bib down some more with a brass valve for future water needs.
Here is what is looks like now. Oh and this my rental house. It was leaking, but I put a new washer in the hose bib and fixed that problem for now.
Cliff notes: Can a really old soldered joint be pulled apart?
