Mach1Rider
:EB... I started out just going to change the spring for the Vs on the carb, so off it came to make it simple to work on. :ecit
Then the while I'm at it hit me.
Lets change the oil... 9qts and a filter later...shot 50 bucks :sad
So now I add the StreetFire Ign box that was sitting on a shelf to her.
I'm running a Mallory duel point mech adv dist.
Following the instructions on the install and removed the trailing set of points. (they are still installed just not wired, so if I ever need a set)
But no where does it say what the point gap or dewell angle should be set to.
Now it starts and runs just fine without any change to the .016 gap on the remaining points.... :vic
But, Does anyone know what the best setting should be?
I did call MSD tech.... But they are off today for employee day? :craz
