slingslingbinks
New Member
I'm in the process of going ahead and replacing both side trunk floor pans while i have the tail light panel out, I suspect other's have done this, But what a burger it was to get to the spot welds between the frame rail and the inner wheel house. I didn't want to drill holes with the spot weld cutter from the wheel side so i got up in there with a 4 inch cut off wheel and ground down the spot welds and popped them loose. And on the front of the trunk floor pan there is a triple spot weld, once again with out cutting from the wheel side i managed to get the spot weld to pop free. I found that this car was rear ended and the tail light panel was already replaced and some one tried to pull the trunk floor pan back into place with a hook inserted at the front of the trunk bumper brace and ripped the floor on the right side and there was a huge crease in the left side. Heres some pictures of the process so far. While i have the frame rail's exposed i will clean them up and por15 them. I also have to replace the old beat up rear cross member. C-ya Scott
