Dne'
I've been using a lesser expensive paint gun/s. They're called "Starting line HVLP" by Devilbiss. I like the color coat gun and pleased with how it sprays, but only now realizing how much the primer gun is used! The top hole in the cover keeps getting stopped up and I take a small drill bit to open it back up, only to get stopped up again, and I don't like the way it sprays, but I discovered after I had sprayed stuff recently, it says 30psi on the handle(primer gun). So I think I was spraying with too much pressure(40psi). It just looks like I used a rattle can to spray with as I can see the lines of the passes that I've made. Any advice on primer guns?
dne'
dne'
