promotorsports eccentric eliminator
i need to do some adjustment to the eccentric eliminators.
do i need to jack and support the suspension to adjust them?
the factory manual just says to undo the bolts, but doesn't mention much else.
i think i finally figured out the adjustment increments and need to redo them.
'67 coupe...by the way, can anyone tell me what settings they're using....4A, etc?
thanks
What numbered hole you use will be determined by what camber setting you need, there is no hard and fast rule. Only way to know is to try each setting and check camber until you get what you want, you may even end up using different holes on either side.
