jonward786
My 68 was an AC/PS car, so it has a 2 groove WP pulley and a 3 groove crank pulley. I removed the non-functioning AC compressor so I'm currently not using the larger 3rd groove on the crank pulley.
After upgrading the alternator to a 3g i'm getting excessive belt squeal and decided to run a dual groove pulley on the alternator. Question is this:
Originally the belt running the PS pump went around crank - WP - PS. Now I need that 2nd equally sized crank pulley for the alternators second belt, so...can i move the PS belt to the larger crank pulley that the AC belt used to be on and just run the PS directly off the crank with no other intermediary pulley? Since the groove on the crank pulley that was originally for the AC belt is larger than the other 2 grooves on the crank pulley, will this increase in RPM for my PS pump do any damage?
