panteramatt
Im puttin my battery in the trunk of my mustang usin 1/0 cable. Ive been told to put the solonoid in the trunk as well. So which alternator are you guys usin as an upgrade? I cant see using an alternator with a voltage regulator as I would have to run the other 2 wires from the alt to the trunk too. The 3g's just use a power cable right since the vr is internal? Im planning on usin 2 gauge wire from the alt to a pos terminal with an inline fuse, then run the 1/0 from the term to the solonoid in the trunk, does this sound right?
