"cmayna" said:Now I'm really confused. If water pump (outlet) is on the lower left side, is the inlet upper on the right side? If so, what is the problem?
"SAC69" said:"cmayna" said:Now I'm really confused. If water pump (outlet) is on the lower left side, is the inlet upper on the right side? If so, what is the problem?
I believe he's saying the rad outlet is on the pass side and the water pump is on the driver side thus the funky lower crossover.
I've seen a similar setup offered for sale by Ron Morris where the water pump is on the driver side & the rad is on the left, when people are swapping in a 5.0 timing cover and keeping the original radiator. It was a formed, bent, polished s/s pipe with two short hose ends. Sounds like you have a home-made similar setup.
Good ID"cmayna" said:You might consider installing a coil into the lower hose to help prevent collapse.
