Can I assume that the seal is fastened in the same manner for a 68 as it is for a 65? I had to replace Shags radiator support losing the factory staple holes. Here's a pic of Reds seal which I was planning to duplicate.
"cmayna" said:Mark,
That's why I posted a pic. Though I've seen most Mustangs stapled like I did with Red, it might not be correct. So you have the staple heads hiding under the big rubber flap then they go through the radiator support and then through the small rubber flap underneath and then folded over? Hmmmmmmmm
"monkeystash" said:How do you staple through the radiator support? Seems like it'd be tough to go through the metal.
"AzPete" said:Yes, it will cause more air to go thru the radiator.
I thought they were only on one engine....either the 6 or the 8....but my memory may be failing.....lol
Thank you. I've been watching this one trying to figure out why I never saw such a thing on any of my cars. Now I'm asking the same as Mark. Why only on six cylinders?"caspian65" said:For 65-66, the radiator support seal was only installed on 6 cylinder cars. But, the correct way, is with staples going through the top if you want to keep it on.
"cmayna" said:Thanks Sir Charles for chiming in. Can I assume all 67 and 68's had it as well?
