Re: Halls Restorations - Gauge cluster
janschutz
Corn Hauler
a couple years ago, bought a 68 tach cluster housing and it turned out to be a 67 version and the tach housing was cut from a cougar housing a clued on with silicone cement. Could not get him to return emails of phone calls to get a refund. Still have that piece of c***.
I "made" my tach cluster using a Cougar Tach and bezel housing. The Cougar "cup" is shallower than the Mustang so I had to section it and add about 1/4" to it but it turned out pretty good. Of course I welded mine also, no glue. If you still got it, I can try to fix it up for you. It won't be "original" but it would be useable.
I also changed the bulb covers from blue/green to red/orange and to make the faces all match I bought a white face kit.
photodisplay.php
photodisplay.php
photodisplay.php
