jims6t6
Is there anything special about the front leaf spring bolt? Will one from the local hardware store work okay? If so what grade?
TIA
TIA
"jims6t6" said:Is there anything special about the front leaf spring bolt? Will one from the local hardware store work okay? If so what grade?
TIA
"silverblueBP" said:I found the closest grade 8 bolt and then cut it to the correct length. Do you need a grade 8, probably not.
