Sluggo
Ok.
I decided to remove the drop blocks in the rear today because the car apparently settled a bit and was i little too low in the back compared to the front.
So I decided to realign it after getting it back together.
First thing I did was got it all mounted and measured.
Here are the initial measurements. Obviously things have moved around since the last alignment. :conf
Next was to address the rear using the satellite readout and get it as close to "straight" as possible.
You can see looking at the picture that the rear is cocked to the right a bit. Both wheels toed out, the right more than the left.
Even using a friction jack I was unable to get the rear any straighter than it was, so I went to the front and adjusted the camber first.
Caster is not a live reading and must be re-measured after each adjustment. Adjusting the camber sent the right caster way out. :yikes
After remeasuring the caster, I took it about 4 wrench turns too far.
I gave it 4 wrench turns the opposite direction. Looking better now. :nice
Just need to set the toe now.
Setting up for bumpsteer measurment.
The car has the UCAs dropped with no corrective action taken to the tie rods.
Even though I've done alignments for years, I would never have guessed I'd see these
kind of numbers for bumpsteer. I quit raising the car at 1.5 inches above stock height.
Alignment printout.
Bumpsteer printout.
Adjustment printout.
Done
ep Just a tad higher in the back than I wanted it but it'll be ok :nice
Alignment printout.
Bumpsteer printout.
Done
