I've removed all the wiring from under the dash of my '67 Mustang. I plan on fixing any splices in the wiring and then retaping everything up. I had an idea and thought I'd pitch it out here to see what everyone thinks.
I've added a new radio, an alarm, and a tachometer. I'd like to have a better solution to running these new items than just taping them on to the original fuse box. The idea I had was to cut out the original fuse box and replace it with something like the attached fuse box. http://www.summitracing.com/parts/PRF-70107/
The new fuse box would be spliced in with solder and shrink wrap. It should add some additional flexibility and get rid of the tube style fuses. I'd sell mine and buy and aftermarket one but the wiring is not bad and I don't want to spend $500 on underdash wiring as I have better uses for the money.
So... What are your thoughts on my idea? Worth the trouble? The fuse box is only $50.
