I noticed my reverse lights were working when I got the car out of the paint shop.
Then as part of the alignment the power steering control valve needed to be replaced. After that the linkage between the gear shift and the tranny was knocked loose.
I put the linkage back on and the reverse lights are not working.
Is the switch that turns on the reverse light incorporated into the neutral safety switch or is there a separate switch?
I was thinking they are basically the same thing with both functions incorporated into the one switch?
