Dne'
I finally got my little 289 running the other day, but just briefly as I didn't have exhaust installed yet, and it did have a popping back through the carb, but didn't give it much thought at that time. So, I had the exhaust installed and able to take note to the popping back much better. I let Herb(the engine builder) listen over the phone, and he said, "sounds like a broken rocker arm". I say, "you can tell me that by listening over the phone!" lol So I took the left valve cover off after finding out where it came from by pulling spark plug wires at the cap(Herb told me how to find where it was) it was number 8 cylinder. After removing the valve cover, there it was, a broken rocker arm! split at the point where the push rod comes up. Herb came over with a new RA, and we worked on it, but found it had a bent pushrod, but he didn't bring one, so I bought a pr the next day, installed it, started the motor and the rocker during adjustment worked its way off the valve and bent that pushrod! argh! Called Herb~ he's so calm! Sounds like I'm going to have to pull that head off! oh rats!
So he asked when he could come over, but I say I can pull the head, and you can come help me put it all back together~ which I went ahead and did. It wasn't that bad to get it dissassembled, but the head is heavier than I cared to lift, so I used my engine crane to lift the head off(brains over brawn!) I could see on the spot where the rocker rides on the valve and it was kind of "worn" looking and that's the way the rocker went off. I don't know what happened, but I'm going back with new roller rocker arms and new pushrods. Herb seems to think that the old rocker arms, or that particular rocker arm was just old and its time was up! lol
Long story short, and lesson learned, Things happens(to put it nicely)! Herb has followed through and I'm so happy to have him as MY engine builder and friend!
