mrgem
I was idling at a stop sign and pulled away in a very sedate (2000 RPM) manner last Friday evening and suddenly my 351 Windsor with fewer than 5k miles on it started knocking and banging. Still had oil pressure -- but it sounded like a small end failure on one of my rods. All I could think about was a 3000 buck rebuild.
I parked the car on the side of the road (nice quiet residential area) and left it there that night. I returned the next morning with my trailer, loaded the car up, and hauled it over to my machinist's house -- which was only about 5 miles away.
My machinist had me start the car and immediately identified the noise as a broken rocker or valve spring...BIG sigh of relief. We popped the valve covers and one of the intake valve rocker arm studs was sheered clean off.
The engine is a 1969 H-code with, stock (ported) 69 heads, with 10.5 compression, a mild performance cam and standard springs, lifters, and pushrods. The studs were the original pressed-in style (a corner I probably shouldn't have cut when we built the motor).
This car, while it has seen some spirited driving, has never been revved over 5k. It makes tons of power down low and the engine was built to make power from 2500-5000 rpm -- something it does quite well. It really doesn't need to spin that hard to be fun.
Because it was built for torque, I really didn't expect I'd need a very exotic valve train.
My question is -- why would the stud fail? Just old, fatigued metal? Flexing/deflecting stock pushrods? I want to put this thing back together so it will last, so I've already decided to go with screw-in studs, but what else can I do to minimize the risk of another similar top end failure?
