Is it wrong to spray epoxy over sanding scratches and block them flat? I have some areas that I used heavy grit to cut the filler down and I did not finish it with the finer stuff. Am I going to get telegraphing of scratches over time if I continue? Should I just sand the area down to the filler and smooth before any more primer?
Thank you. :shrug
Thank you. :shrug
