Hey John, have you ever considered using a screw in ball joint on the body side of an adjustable strut rod? I'm thinking you weld a sleeve into the strut rod bracket, screw in the ball joint, then have a turnbuckle to connect the ball joint to a modified (cut and threaded) strut rod? seems like it would be simpler than some of the clevis/rod end designs out there...
you think it would work?
Just an idea I had...
