82firebird
New Member
I am looking for help to complete our engine setup and fuel system. Other than the engine and supercharger, the car is a blank slate. I have no tank/lines/pump/regulator,etc. The engine as we purchased it is shown here:
•Stock 351W block, fully prepped and bored .040-inches over (360ci)
•Stock Ford 351W crankshaft, .010-inches under on mains/rods
•Ford rods, shot peened and ARP rod bolts installed
•Probe forged pistons w/ Perfect Circle rings, 8.9:1 compression
•Completely balanced (crank/rods/pistons/damper)
•Edelbrock Performer EFI 351W intake
•Accufab 75mm throttle body/EGR spacer
•42 lb/hr Ford Racing fuel injectors
•High-flow billet fuel rails with AN fuel line connections
•Edelbrock Performer cylinder heads
•Probe 1.6:1 full roller rockers
•Professional Products SFI rated balancer
•Elgin flat tappet camshaft (.496/.520 lift, 224/234 duration, 112 lobe center)
•Engine is machined for roller cam if a cam swap is desired
•Double roller adjustable timing chain and gear set
•Manley pushrods
•Pro Mustang 7-quart oil pan
•Melling high-volume pump with Probe Ind. HD drive shaft
•MSD EFI distributor and 8.5mm Super Conductor plug wires
•Complete Fel-Pro gasket set
•Edelbrock water pump
•Coast High Performance cast aluminum valve covers
•Paxton NOVI 2000 centrifugal supercharger with all brackets
The car was away at Gillis Performance and we just received at back home. I had them remove the upper intake when they dropped the engine in, because it was very close to hitting the hood. I didn’t want them to have to spend the time figuring the clearance out, so the upper intake was removed. I should know later this week (when I have the time) to see if the hood will clear the Edelbrock Performer intake. If not, what is my next best solution? Ditch the EFI and go carb with an enclosure or carb hat?
Should I choose my fuel delivery before planning the fuel system? I would like to use a nice tank, such as this: http://www.atomicfabrications.com/Item.aspx?ItemID=5015
How about fittings, line size, etc?
The engine dynoed at 515hp/541tq @5,000RPM. The car will be street driven only, never raced and never tracked. I want a well-mannered street machine that we can enjoy driving. I appreciate all of your insight!
•Manley pushrods
