Shelby rear seq lights ?
lep17
New Member
Hi would anyone no how to completely turn off the turn signals on the shelby rear Sequential led lights ? I only need them for side and brake lights . I cant get the car passed a gov inspection with them . I am using the bottom two back up lights with a seperate amber light installled in them as my turn signals .
Thanks
I would say locate the controller or 'dynamite sticks' as they are know and bypass it. You should be able to figure out which wire coming from the froont of the car, down the drivers side I believe gives the TS power with a $5 test light. Once you locate which wire heads to the TS run a bypass wire(s) around the controller to the bulbs.
This thread may help with lots of DIY dynamite stick info and drawings:
http://www.stangfix.com/testforum2/inde ... 751.0.html
Jon
