Chris Kennedy
Hi:
I have a 65 289 automatic, and I am on my third replacement shift indicator light assembly (this is the assembly that includes a bullet shaped capsule which snaps onto the shift lever and contains a bulb inside). For some reason, all these repro. assemblies work for only less than a day and then the connections go bad to the bullet assembly and a plastic assembly inside the bullet casing sort of melts onto the bulb. Jiggling the wiring into the assembly works for a while, then it stops working. It's the world's simplest thing yet impossible to fix. If there was too much power going in, I would think the bulb would blow first. Any ideas? I am thinking about trying an original, used one next, or just not worrying about it. I am also wondering whether using they used a different bulb in 65 which avoided the problem altogether.
Cheers,
/s/ Chris Kennedy
Cheers,
/s/ Chris Kennedy
