Stupid question probably but is there supposed to be some sort of spring in an automatic shifter button so that when you push it in to select a gear it returns back to the "out" position?
My shifter has been having issues and I figured it out this evening. The pawl is not coming down enough on the plate at the bottom because of the button in the handle. If I take the handle off and move the ball with my hand it works great but if I put the handle back on the button sticks at the pushed in position for lack of a better way to describe it....currently you have to make darn sure no one bumps the gear shift handle when you are driving.
