AtlantaSteve
In chat last night I was talking about my side scoops and Jake asked me to start a thread on it, so here it goes.
What I've done so far:
*Taken out the rear windows(not looking forward to putting them back in)
*Removed the "Fingers" side trim that they put on most '66s
*Welded the holes that held the trim on shut on both sides
*ground the welds on the passenger side
*scuffed the paint on the passenger side(so i can put some rattle can primer over the new exposed metal. This is temporary, and not final body work.
So, I have a general rule about not doing too much welding on anything anyone will see on the car, because I have the cheesiest welder (Campbell Hausfield 90 dollar Flux-Core only Wire feed I bought at WalMart almost 10 years ago) and because I am not very good at it. This is my first real stab at body welding...I figured it's not such a big deal since all this work will be hidden under the scoops anyway.
So here's a few pictures. I took them on my iphone in my dim garage, so they suck, but hopefully you get the idea
The new scoops
New scoop compared to the "finger trim" that came off the car
Passenger Side panel. Holes welded shut, weld ground down, paint scuffed
Mockup of the scoop taped to the side of the car testing fit. Finally got the pretty close!!
closeup on some of the welds. You can see I discolored the metal because I don't grind gentle enough. Think I probably overheat it while grinding.
The welds, pre grinding, on the Driver side. Unfortunately, this is some of the best welding I've ever done. The passenger side I made some giant mountains that took forever to grind down. These are fairly flat and will require a lot less grinding to get smooth. Hopefully the poor quality photo does an ok job of masking my poor quality welds
Close up of the Driver's side pre-ground welds. Why I'd want to get close on these is a mystery.
So next up is to get some wax and grease remover, and clean up the sanded paint. Shoot some cheap primer over it, and then drill and mount the scoops. I SHOULD skim a little body filler over the welds, but I'm not sure if I'm gonna mess with it for now.
Any comments are welcome. If I'm screwing up let me know.
The new scoops
