steveh326
Is there a good way to smooth the underside of a fiberglass hood where the fg is not doubled up and the rough texture is visible?
"mustangstofear" said:Our hoods are finished on the underside, but there is a product that I have called Reface designed for fiberglass, it has a mill thickness of 7.5 compared to a high build primer that I use which is 4.5, 2 or 3 coats of this will smooth out your rough fiberglass.
