Snap tool NEEDED for resto
Mach1Mark
Ramrod extraordinaire
Im restoring my wind wing assemblies on my '65 and I just discovered I need a special tool. Does anyone have this tool they would loan or rent for a couple of weeks? I say weeks because I don't know how long the plating shop will have the main frames. Thanks for your reply.
"cmayna" said:
What on earth is that tool needed for?
I believe it is for the blind rivets used to attach the weatherstrip channel... On my chebby they use a blind rivet for the wing window pivot. I got a couple different sizes of these...
http://www.ebay.com/itm/Rivet-Set-AN450 ... 416906b323
So long as you have a way to support the back / flat side of the rivet, you can use a hammer to tap this tool and compress the flared side. It fits in an air chisel, but I thought it might be a little too aggressive and just hammered it by hand with a small ball peen hammer.
As noted by 6T6Red, you can use regular rivets so long as you have a narrow headed rivet gun...
I used the stock style rivets, a hammer and a punch. Not perfect, but functional...plus they are hidden anyway.
Sent from my iPad using Tapatalk
Ah,,,,now I remember. Yup just used hammer and pointed punch to set the rivets. Supported the channel using a 1/4" thick chunk of flat steel. Did this for both Red and Shag.
