RyanG85
I'm relocating the headlight harness out of the engine bay. I'll be switching to an internally regulated alternator and a late model mini starter. I'll be locating the battery into the trunk. I would like to eliminate the solenoid since the mini starter will have its own. How many wires do I need to run from the Battery to the engine bay? 1 heavy gauge to the starter and a smaller one from the Alt back to the battery for charging? Will also be running a few relayed hot lines for the electric fan and headlights, Do I run those lines off the starter solenoid positive? Should there be one line off solenoid positive to a junction block and then to the relayed accessories? I'm kinda an idiot when it comes to wiring.....
Those with trunk mounted batteries, where did you run the wire, under the car or under the door sill plate? Does the Neg just get grounded to the trunk floor?
On the mini starter, will the signal wire from the key need to be relayed? I've read some say yes, some say no.....
Again, sorry for the novice electrical questions and thanks in advance to all those that reply.
