sigtauenus
For the guys who have stainless lines and Dot 5, what is the trick to getting the lines to seat? I understand the Dot 5 will find a leak easier than Dot 3, and I still have a couple junctions that are weaping. Nothing heinous, but still needs fixed. Do I need to just keep loosening and tightening the fitting or replace the lines altogether? At this point I'm contemplating flushing the system a couple times with alcohol and going back to Dot 3 and seeing if that works. I'm hesitant to do that, because if the Dot 3 leaks too, then I have a mess with my paint (the reason I went with Dot 5 to begin with) and I still have to fix the leak anyhow. If its going to leak regardless, I might as well fix it and stick with Dot 5.
