Aussie67
Need some advice. 302W in 67 coupe.
Some of you may remember but some time back i installed a high torque starter and retained the solinoid on the fender. However I didn't change the wiring so I get some run on after the motor has started.
To fix this I understand that I need to change the battery cable whi h runs to the starter to the first (closest to battery) terminal and run a new wire from the "S" to the solinoid on the starter.
Is this correct?
Is this correct?
