My 68 FB has recently developed the annoying habit of losing all electrical power without notice. It has happened 3 times now, and 2 of the three times it came back in less than a minute.
When I say all power, I mean all power - no headlights, no courtesy lights, won't crank, no ignition, nothing!
Any ideas how this happened? I'm assuming there must be a an intermmitant open circuit somewhere between the + post on the relay and the under dash harness. The harness near the relay is a bit of a cut and splice job from the PO, but I've unwrapped about a foot of it and there aren't any fuses or fusible links to be found. There isn't some circuit breaker between the relay and the fusebox is there? Somehow whatever went wrong resets itself.
Obviously I'm a bit nervous taking it back out on the road since it can apparently shut down completely for no earthly reason. There doesn't seem to be any rhyme or reason either - In one case it cut out after driving about 10 minutes on a warm day, and this morning I backed it down the driveway, shut it off, then went to restart it 5 minutes later and no juice. I waited another 30 seconds and it was all back on again!
Thanks,
Andrew
Thanks,
Andrew
