I replaced my front suspension earlier this year. The car drives well on smooth roads. If the road is not smooth, it feels like an old truck. It is very rough and sounds like I bouncing down the road. I could use some advice improving the suspension. I want a good compromise between comfort and cornering ability.
Let's start with what I have installed: OpenTracker stock style UCA and LCA, roller spring perches, 1 1/8 sway bar (from Dallas Mustang), heim joint adjustable strut rods, existing Monroe gas shocks, new springs, and all new Moog steering components. The spring isolator is made of Midolene (NPD) and the sway bar end links are Energy Suspension poly pieces.
The springs are not common so I'll need to explain what I did. I purchase the HD style springs for a '68 Mustang from NPD. These are made by Eaton and rated at 428 lbs. I cut off a little less than 3/4 coil to get the ride height to be a little less than stock. Based on the explaination on the Eaton website, I believe this results in a spring rate around 450. I chose to do this so it would be better than stock but a little less stiff than a 620 spring.
I've checked everything to make sure nothing is loose as it sounds like it. However, everything is torqued per the Shop Manual. I'm wondering what could be the problem. Maybe I should have replaced the shocks rather than reuse the Monroe shocks I had. If I push down on the fender and release the car with go up and then stop which I was always told was a good way to see if a shock was bad (might be way off here).
Any suggestions are greatly appreciated. I have plenty of work left to do on my car so if different parts are in order assume a fairly small budget.
