SELLERSRODSHOP
o.k., so i get my new flywheel installed & torqued down, then pulled out my new clutch stuff. installed the new pilot bearing (should i give it a little dab of grease?) & go to install the clutch. well, first, the pins in the ford racing clutch fastener kit dont fit the pressure plate. they are stepped, & the hole in the flywheel is the same as the pressure plate. found some transfer punches & drill bits to align the pressure plate, but how important is it to have them in after the pressure plate is bolted down? also, the bolts didn't fit either. figured with a late model clutch & flywhhel to match, it would be metric, but is 5/16". what grade of bolts should i pick up for this tomorrow? grade 8??
