Hello,I'm a newby to the forum. If you saw my intro, I am restoring a 66 coupe which I am swapping a t5 for the original C4 tranny. I have the tranny installed, but have confusion as to how high it should sit in the trans tunnel. Some have said that thee shifter box should sit flush with the shifter hole, but mine is about an inch below the hole, with the rubber boot sticking up about 3/4". I used the crossmember that Mustangs Unlimited sells with the original C4 trans mount. The t5 is bolted to a 289,using a later model 6 bolt bell housing.
Any help would be much appreciated.
