Hi, My tach, gas and three gauge in my 73' Grande are not working. If I turn the key, gas gauge will work until I start the car. Sending units for temp and oil pressure are new, above engine wiring and Alt. wiring for gauges is new. Alt. and regulator are new also. I'm not getting power to the gauges. Coil has two wires on the Battery side(tach and power) and one on Dist side going to the Dist. I'm going to test the Alt. to make sure that its working properly and clean the ignition switch. Have checked all grounds and wire connections. Tach and all gauges have been cleaned and tested. Any other ideas. Please HELP! Thanks, Brian
