kb3
I started installing the TCI rear suspension today on the boy's car. The rear sub-frame connector mounts at the former front leaf spring mount. You need to drill three holes into the cabin and bolt through. In the car you are suppose to install a three hole plate with the bolts. These come up under the rear seat. As can be seen in the below photo, there is a raise in the floor (underneath the rear seat) that would keep the plate from laying flat. The third hole in fact is on the downside of the raised section.
Has this floor plan been replaced?
Does anyone else have pics of their floor pan?
Yes I know I have the plate installed one hole too far forward. I am contemplating cutting it to leave the first two holes in front of the raised area.
HELP???
HELP???
