Fst Blk
I had planned to convert over to a throttle cable setup for the 67. I even have a fox pedal, but now I'm debating this. I have the stock automatic linkage that has the kickdown bracket.
I plan to run a manual so the kickdown isn't needed. I need this
I can remove the kickdown correct? And I'm assuming it's the same linkage once that is complete?
Anyhow, need some pics to figure out how this works. If I use this, I'll get a rod and heim joint to connect from the carb to the linkage? What about a return spring? What would you guys do? Stock style linkage or throttle cable using the fox pedal.
