:rant Okay, this is about the '56 cheby in my sig pic. I still need help here even if it is the cursed enemy of Ford! Background: It has a 350 engine/350 tranny with a fairly new Edelbrock 600 carb and a Mallory HEI distributor with the vac. advance. I have tried this with the vac line hooked up to the carb on both ports at different times. I had to really advance the timing (I will have to check this Friday with the timing light to see what it really is) by ear to get it to stop hesitating on take off. It runs like a champ like this! The problem is when going to crank it, it cranks like it is really struggling against compression. Barely turns over and then catches and starts right up. If I reduce the timing, it starts right up but hesitates on hard take off. I have already tried changing the carb step up springs/bigger needles etc...no change on the hesitation. I am wondering if I need to change the springs out on the distributor (lighter?) to make the advance come in faster, thus stopping the hesitation and allowing me to put the timing back around 12 deg. or so? Heck, it is probably at 25 or 30 right now! Help would be appreciate on this, thanks, Gary!
