I removed my Toploader transmission and rebuilt it. I've resurfaced the flywheel and plan to install my new Centerforce II clutch this week with the rebuilt transmission. I've a few questions about the process.
1) Should I put a light layer of RTV on the block plate before installing it back on the motor?
2) I'm not positive of the orientation of the flywheel when I took it off. Is it place on in a particular orientation (offset weight opposite of harmonic balancer)?
3) I removed the flywheel bolts with a friend holding the motor from turning using a wrench on the bolt at the harmonic balancer. This does not seem like it will work for reinstalling as the front bolt would just come off. How to you keep the motor from turning while installing these bolts?
Thanks in advance for the help.
