"Midlife" said:There's usually a little ring that goes on the bottom of the steering wheel with two bumps. These bumps hit the cancel protrusion on the turn signal switch. If your wheel is aftermarket, some use rolled pins in place of the little ring.
If the ring or the pins are missing, nothing will cause the turn signal switch to return, except the digital version, which you are already using.
